Warning message
VPN 3000 SNMP monitoring
Dec 16th, 2002
I am trying to get MRTG reports setup on our Cisco VPN 3015 Concentrator. It is version 3.6.1.
I have successfully graphed Interfaces, CPU and Active Connections, but the last value that I would like to keep track of is Memory Utilisation. I have found the following OID which shows me how much RAM is in the box:
.1.3.6.1.4.1.3076.2.1.2.22.1.59.0 Physical Memory in Mb
I have been unable to find a variable that tells me memory usage.
Can anyone help.
Darryl Ormston
rmushtaq Tue, 12/17/2002 - 10:29
  • Blue, 1500 points or more
.1.3.6.1.4.1.3076.2.1.2.22.1.59 is the correct object here. I tried it on one of VPN 3030 boxes and it shows the correct value:
For example, on the VPN Menu, it shows:
Up For 69:19:47
Up Since 12/14/2002 13:05:23
RAM Size: 256 MB <---- !!!!!
And polling using the above OID, give the same result :
% snmpwalk public .1.3.6.1.4.1.3076.2.1.2.22.1.59
enterprises.3076.2.1.2.22.1.59.0 = 256
