12-17-2002 09:49 AM - edited 03-02-2019 03:39 AM
Hi! I have actually running EIGRP between two routers over a frame relay link. I have two PVCs are operating over the same link one with CIR 384 the other CIR 128 kbps. The first PVC its EIGRP preferred to transmit information, but I am wasting bandwith...How I can balance the trasmit information between two PVCs??
Thanks for your help Felipe
Solved! Go to Solution.
12-17-2002 11:16 AM
Although this document refers to IGRP, it still applies to EIGRP. This should
get you on the way.
12-17-2002 11:17 AM
U can use variance command in Eigrp for unequal load balancing.
In ur scenario, u can use variance 3.
Check out this link:
12-17-2002 11:16 AM
get you on the way.
12-17-2002 11:17 AM
