Warning message
AdmitOne VPN Client & Cisco VPN
Dec 17th, 2002
I have a manager that wants to setup his IPAC as a VPN client to my PIX, but am unfamiliar with the config of AdmitOne. Has any one used this before in this config? I get lost when it asks for a user and secretpassword, where I believe it should ask for VPNGroup + secretpassword. I cannot find any specific instructions for using this software in this config.
Nelson Rodrigues Tue, 12/17/2002 - 21:49
  • Cisco Employee,
Robert, I've never used the AdmitOne VPN client from www.funk.com. But I've done a bit of research on their Web site and have these 2 links that will help.
1) What to configure on the VPN gateway server for this client. They have an IOS device, not PIX, but should be in ballpark
http://www.funk.com/subsections/a1technotes.asp
2) The AdmitOne Manual
Chapters 3 and 4 describe in detail how to login to the IPAC and how to setup a VPN tunnel.
The user/secret password you refer to are to log you in to the Ipac Secure Policy Store database (simply a database of users permitted to use the pocketPC). This user/secret passwd is not to be confused with the VPN credentials (group/passwd) you will use as pre-shared keys. Here is the link:
http://www.funk.com/Docs/A111MAN.PDF
Good luck.
Nelson
ROBERT CROOKS Wed, 12/18/2002 - 05:34
Thanks for the reply.
I see what you mean by it being a router config. I think that I can use it to derive what the PIX should be.
Just a question though, does Cisco have any intention of developing a client for Windows CE? Using the same client look & feel everywhere (like with MAC OSX) is great.
Thanks Again
Robert Crooks
pdentico Wed, 12/18/2002 - 17:46
We've been using the Movian VPN client by Certicom with the pix successfully.
We did not have much luck with the Admit One client.
Good Luck
ROBERT CROOKS Thu, 12/19/2002 - 10:39
Do you know where I can get a any configuration help from Movian?
pdentico Thu, 12/19/2002 - 17:58
You have to request the download from them. I had to go back and forth a few times with email to their support dept. before they sent me a pix config. Unfortunately I'm out of the office for the rest of the week so I don't have it to post.
concom Fri, 01/03/2003 - 09:10
I've problems trying to configure the movian vpn client with PIX, can you explain me how can I configure it?
