Warning message
PIX NAT Translation Problem
Dec 19th, 2002
Hello All I have the following situation on a PIX 520 running 6.2.2
I have three interfaces inside, outside, dmz
on the outside interface have an access-list which permits icmp from any to the IPs behind the DMZ interface, I have the following:
access-list external_access_in permit icmp any 1.1.1.0 255.255.255.0
nat (dmz) 0 1.1.1.0 255.255.255.0 0 0
access-group external_access_in in interface outside
1.1.1.0 are routed ip addresses in internet, the above permits outside hosts to ping my hosts behind the dmz interface
I am trying to do the same trying to permit the hosts behind the dmz to icmp ping the hosts behind the inside interface:
access-list dmz_in permit ip any any
nat (inside) 0 1.1.5.0 255.255.255.0 0 0
access-group dmz_in in interface dmz
The inside permits inbound by default.
But I have in the log :
305005: No translation group found for icmp src dmz:1.1.1.1 dst inside:1.1.5.1 (type 8, code 0)
According to me the situation is the same like pinging outside to dmz.
I have:
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
Does anyone could tell me where I am wrong, and how to permit the dmz hosts to icmp ping the hosts on the inside interface.
Thanks for your answers.
c-cn Fri, 12/20/2002 - 04:44
you need static entries for nating, like that:
static (inside,dmz) 1.1.1.0 1.1.1.0 netmask 255.255.255.0 0 0
static (inside,outside) 1.1.5.0 1.1.5.0 netmask 255.255.255.0 0 0
