12-20-2002 11:53 PM - edited 03-02-2019 03:45 AM
If you are getting erros on one ISDN B channel and not the other, what is this more likely going to suggest as to being the fault? The line or the router?
12-21-2002 09:39 AM
Most likely it will be a telco issue..You need to talk to telco to do BERT test on that line to see problem and fix it.
Log in to Community
