Warning message
What causes FCS Errors in Wireless Network
Dec 23rd, 2002
I currently have a Cisco wireless LAN solution engine that is reporting several
"FCS Error is in Overloaded state" messages on several access points. and also
"Packet Error is in Overloaded state" These error messages will be followed by another message stating the Packet Error and FCS Error is in an OK state. Can anyone tell me what this means.
fmeetz Fri, 12/27/2002 - 09:51
  • Bronze, 100 points or more
This seems like it may be a switch issue opposed to an AP issue. Basically the message is stating that there are too many packets that have bad check sums and they are being dropped. Read over the following link to see if that helps out.:
http://www.cisco.com/warp/public/473/53.shtml
jakew Fri, 12/27/2002 - 11:15
  • Silver, 250 points or more
We believe the high number of FCS errors on the APs reported by the WLSE is typically related to non-harmful signal propagation errors (signals bouncing around). If your utilization is OK and if none of your end-users are complaining, I would recommend disabling this fault threshold.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
