12-24-2002 09:40 AM - edited 03-02-2019 03:47 AM
I have a WIC 56K 4-wire CSU/DSU installed in a Cisco 1720 router. The CSU/DSU is connect to a Frame-Relay DS0 circuit. The serial interface is configure with the following statements:
interface serial 0
encapsulation frame-relay IETF
service-module 56K clock rate 64
frame-relay lmi-type ansi
My problem is the serial interface will not stay active and I'm receiving framing errors. Can some tell me if this card - WIC 56K CSU/DSU will work in this configuration. If yes, it the configuration for the serial interface correct?
Router IOS IP PLUS 12.2.5
Thanks in advance
12-24-2002 09:52 AM
you need to enter the command
service-module t1 timeslots xx (number of ds0's)
service-module t1 fdl both (this will allow for the carrier to loop your card )
12-24-2002 11:03 AM
Having the same problem. I was told to check the telco to see how the circuit was built - if it is a 64k clear channel then it will work. But if it is a T1 access using a single DSO as the port speed (64K) then no, you will have to upgrade to the T1 DSU.
Good luck to us!!
