Warning message
dlsw vmac translation problem
Dec 24th, 2002
I have topo like this:
(390)--sdlc---(router a)-------wan------(router b)---ethernet----(as400)
appc session can't established,so I capture frame on router b's ethernet,but I found the test frame:
smac=0200.0000.2083
dmac=4242.4242.0640
ssap=0
dsap=4
I don't know why(ios bug or ???),I think the correct frame maybe like this:
smac=0200.0000.2083
dmac=2424.2424.0640
ssap=0
dsap=4
the ios version is :
router a: c2600-is-mz.122-7b.bin
router b:rsp-a3jsv-mz_121-4.bin
following is config of router:
router a:
dlsw local-peer peer-id 10.1.1.1
dlsw remote-peer 0 tcp 10.8.1.1
interface Serial0/1
no ip address
encapsulation sdlc
no ip mroute-cache
no keepalive
sdlc role secondary
sdlc vmac 4000.0000.0400
sdlc address C1 xid-passthru
sdlc partner 4242.4242.6002 C1
sdlc dlsw C1
router b:
dlsw local-peer peer-id 10.8.1.1 promiscuous
dlsw bridge-group 13
interface FastEthernet6/1/0
no ip address
ip route-cache distributed
full-duplex
bridge-group 13
bridge 13 protocol ieee
dixho Thu, 12/26/2002 - 13:43
  • Silver, 250 points or more
Please use "show dlsw reach" on both routers and find out if the MAC address in DLSw reachability cache is correct or not.
Please also try debug DLSw reach.
c.chunxia Thu, 12/26/2002 - 18:18
My as/400 eth's mac is 4242.4242.0640,so I think the correct config of dlsw partner is
2424.2424.6002. If I config 2424.2424.6002,the mac can't be found. if I config
4242.4242.6002,the mac can be found. Like something is error,DLSw is try to chang my MAC
addresses between canonical format and noncanonical format, but it only change the last two byte. And you can see,dlsw can translate correctly the destionation of as/400 0200.0000.4080 to router's vmac 4000.0000.0201.
interface Serial0/0
no ip address
encapsulation sdlc
no ip mroute-cache
no keepalive
sdlc role secondary
sdlc vmac 4000.0000.0200
sdlc address 01 xid-passthru
sdlc partner 4242.4242.6002 01
sdlc dlsw 1
interface Serial0/1
no ip address
encapsulation sdlc
no ip mroute-cache
no keepalive
sdlc role secondary
sdlc partner 2424.2424.6002 C1
sdlc dlsw C1
router a#sh dlsw rea mac
DLSw Local MAC address reachability cache list
Mac Addr status Loc. port rif
4000.0000.0201 FOUND LOCAL Serial0/0 --no rif--
4000.0000.04c1 FOUND LOCAL Serial0/1 --no rif--
4242.4242.6002 SEARCHING LOCAL
DLSw Remote MAC address reachability cache list
Mac Addr status Loc. peer
4242.4242.6002 FOUND REMOTE 10.8.1.1(2065)
2424.2424.6002 SEARCHING REMOTE
router a#sh dlsw cir
Index local addr(lsap) remote addr(dsap) state uptime
3556770440 4000.0000.0201(04) 4242.4242.6002(04) CKT_ESTABLISHED -
dixho Fri, 12/27/2002 - 14:37
There are certain pattern is the same in both canonical and non-canonical format. 42 is one of it. The binary for 0x42 is 0100 0010. If you read from right to left (canonical), it is 0x42. Similarly, it is 0x42 if you read from left to right (non-canonical). It looks to me that the router translate the MAC address correctly.
Please sign on to CCO and go to the following URL:
http://www.cisco.com/cgi-bin/Support/Bitswap/bitswap.pl
The above URL helps you to translate MAC address between non-canonical and canonical.
From the output of show dlsw circuit, it shows that there is a DLSw circuit between the host and the AS/400. The state of the circuit (ckt_established) means that the host and the AS/400 is exchange XIDs. If the circuit does not go to "connect" state, it means that the host and the AS/400 do not agree on certain parameters. It is usually caused by a configuration issue on the mainframe and the AS/400.
I need the switched major node definition on the host and the host controller description on the AS/400. You may want to open a TAC case.
c.chunxia Thu, 12/26/2002 - 18:53
And I found other device on the same ethernet can be translated correctly
So have the as/400 's problem ?
cisco 7507
cisco 7507 's ethernet mac is :
r7507#sh int f4/0/0
FastEthernet4/0/0 is up, line protocol is up
Hardware is cyBus FastEthernet Interface, address is 0007.ece1.2080 (bia 0007.ece1.2080)
0007.ece1.2080 <---------> 00e0.3787.0401
router a #sh dlsw re
00e0.3787.0401 FOUND REMOTE 10.8.1.1(2065)
4242.4242.6002 FOUND REMOTE 10.8.1.1(2065) max-lf(1500)
