dlsw - question
Dec 25th, 2002
hi,
my question regarding dlsw config:
i have a cisco 7513 router on which i have configured 3 different virtual rings because of a cip-interface
and so on:
source-bridge ring-group 10
source-bridge ring-group 20
source-bridge ring-group 30
so i have 3 virtual-rings on this router.
now i have the task to enable dlsw to other 200 routers on which i have to transport over 1000 sna-sessions.
is it possible to configure this router in such a way, that if it gets sna-frames (explorer,..)
from the 200 routers (and therefore 1000 sna-session) that the dlsw-prozeß forwards these frames only to one
certain virtual ring - for example only to virtual ring 10 ??
i want to avoid that if the net comes up that these 1000 explorers are forwardet to all three virtual rings -because of
cpu util!
i think the default design of dlsw is to forward this traffic to all virtual rings.
thanks and greetings from austria and a happy new year 2003 !
beth-martin Tue, 12/31/2002 - 12:57
  • Bronze, 100 points or more
You may want to contact Cisco directly to see if they have the answer you are looking for.
vmiller Tue, 12/31/2002 - 13:52
  • Gold, 750 points or more
I wouldnt worry about the virtual ring, your data target is a mac address of a host. WHich ever Ring sees that host will handle the traffic.
How are you defining your DLSW peers ? If you are doing static peering, your
setup overhead is considerably less, since the routers do a capabilities exchange on which mac addressess they can reach.
