Warning message
C2950G-48-EI can not be known in campus manager
Dec 29th, 2002
I used some C2950G-24-EI and C2950G-48-EI, and I installed the cat2950 device package 3.0.
Now I encount the problem that I can see the c2950-24 in campus manager, but campus manager treat the c2950-48 as "ciscoproducts.429" device.
The other problem is the Gigastack GBIC can not be seen in cisco view.
Thanks a lot
rmushtaq Mon, 12/30/2002 - 10:21
  • Blue, 1500 points or more
What is the version of Campus Manager that you're using?. The device package is that for CiscoView only and has not affect on the functionality of Campus Manager. CiscoView and Campus Manager are separate applications.
Only Campus Manager 3.2 supports 2950G-24-EI per:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/camp_mgr/sup_dev/cm_3_2.htm
