Warning message
How to reach a second net through vpn......
Jan 6th, 2003
I have conf. a cisco 1721 and a WatchGuard firewall. The tunnel between the two sites works fine. But on the cisco site I have another remote net which I want to reach over my vpn. On the cisco site I added an other access-list allowing the net on the other site of the vpn to access the remote net on the cisco site.
access-list permit ip 192.40.200.0 0.0.0.255 192.168.77.0 0.0.0.255 (works)
access-list permit ip 192.40.211.0 0.0.0.255 192.168.77.0 0.0.0.255 (is this
acces-list wrong or just not enough on the cisco site to get it working ??????
lars
jfrahim Mon, 01/06/2003 - 12:34
  • Cisco Employee,
Hi Lars,
All you need to do is to add another entry in your existing Encryption ACL
For example, if you had:
access-list 100 permit ip 192.40.200.0 0.0.0.255 192.168.77.0 0.0.0.255
to encrypt the traffic, then all you need to do is add:
access-list 100 permit ip 192.40.211.0 0.0.0.255 192.168.77.0 0.0.0.255
That's all on the Cisco side.
Make sure that Watchguard supports having multiple SA ( or multiple subnets ) going to a specific peer. I think there are many different vendors who only support one subnet per peer for the IPSec connections
Hope that helps
Jazib
