12-18-2002 12:45 PM - edited 03-02-2019 03:42 AM
I want to use the same icons commonly used in the Cisco white paper documentation. Where is the stencil for VISIO?
12-18-2002 12:45 PM
To download the cisco conceptual visio stencils go here;
03-10-2010 01:39 PM
Use in Microsoft Visio.
Last updated April 1, 2009
PMS 3015: ZIP (480 KB)
Black and White: ZIP (480 KB)
Grayscale: ZIP (480 KB)
Color: ZIP ( KB) (Need URL) <----------------------------------- THIS ONE IS MISSING
03-21-2010 04:15 PM
Correct me if I'm wrong, but the Cisco stencils don't have the ability to make use of the visio connection points and the data attached to an object.
This makes it useless for me.
12-22-2011 07:51 AM
take a look at the Cisco Visio Add-on at
http://www.cisco.com/en/US/products/hw/prod_cat_visios.html
It provides a wealth of data entry options for cisco icon.s
01-26-2018 05:05 AM
Actually i believe you were wrong. They have less connection points but enough to make proper design and dynamic adjustments.
Best
09-27-2018 05:50 AM
Sorry but I've not found visio stencil for VS-C6509E-SUP2T inside that web page.
03-01-2011 04:13 AM
Microsoft provided many Visio Stencils at Visio websites, however, if you want to create your own Visio Stencils you can create it in Visio 2010 in the following way
1. On the File menu, point to Shapes, and then click New Stencil.
2. To save the stencil, right-click the stencil title bar, and then click Save.
3. Type a name for your stencil, and then click Save..
05-28-2013 07:31 PM
06-13-2013 07:54 PM
There appear to be even newer "flat" icons being used in Cisco materials. Does anyone know if these are hiding online somewhere? The visio page haven't been updated in a while as far as the conceptual icon look and feel.
Example
06-18-2013 11:21 PM
Example
I've been looking for these as well. Cisco, are these available?
06-21-2013 12:36 PM
Can't seem to find conceptual vss for the entire Nexus product line.
07-02-2013 03:14 PM
They have some new/purple colored logical icons as well that are pretty cool. They were widely used in the slides created for Cisco Live this year in Orlando...can't seem to find them anywhere thoguh...
03-13-2014 05:43 PM
03-07-2019 11:53 AM
