Warning message
Desperate search for this answer
Heres the # to the question as asked in the Cisco testing software that accompanies the 640-607 certification kit. It is the esim question that asks you to set the serial links up and ping them between the router. I have my exam saturday and if anyone can figure this out I will be in their debt.
Question # 3504
Thanks very much guys, if you have the software you'll know what question I'm talking about.
Dave
j.stringer Wed, 01/08/2003 - 06:07
I'm not too sure on the politics of answering your question, but if it is the same question I had (simulation question, can't ping between two routers, troubleshoot and reslove issue??) .... I would suggest you check the configuration of the two connected interfaces. BE THOROUGH !!! (I can't just GIVE you the answer) Good luck on the exam. Sorry if this isn't what you're loking for.
