Warning message
CD One 3rd install problems
Jan 9th, 2003
I'm trying to install CD One 3rd Edition on Intel Xeon with Windows 2000 server with dynamic disks configuration.
I get an error message "Cannot create install dependency file" as soon as i choose the install directory.
On a pentium III server I get no problems. Can this error be because of the Xeon proccessor or the dynamic disk?
gev Thu, 01/09/2003 - 04:51
More information on my problem:
The errors in the installation logfile:
MAIN: ProcessBeforeConfirmation START at 14:34:35
Executing command:
"D:\dependency\jre\bin\jrew_dep.exe" -cp "D:\dependency" DependencyHandler "C:\Program Files\CSCOpx\setup" C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\_ISTMP1.DIR\_ISTMP0.DIR\setup C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\_ISTMP1.DIR\_ISTMP0.DIR\Depends.in
MESSAGE
Cannot create the install dependency file.
MAIN: CleanUpInstall START at 14:36:55
MAIN: Installation complete at 14:36:55
rmushtaq Thu, 01/09/2003 - 10:35
  • Blue, 1500 points or more
Looks like you're hitting CSCdt26215 which is fixed in the latest version.
gev Fri, 01/10/2003 - 00:28
In my situation, the error ocurs before any progress bar shows.
The installation terminates with no "press OK to continue" option.
