Warning message
How do I show the 'bandwidth' allotment in a 7206VXR?
Jan 9th, 2003
In a 7206 I am only allowed a certain amount of 'bandwidth' per box, which makes me have to be particular with what modules I can install. Is there a command that will tell me what bandwidth is already used up so I can decide if I can install certain blades?
Bradley Littlejohn Thu, 01/09/2003 - 12:56
  • Cisco Employee,
Bandwidth usage is dynamic. You will have to use a product like concord to poll the interfaces.
vmiller Thu, 01/09/2003 - 16:08
  • Gold, 750 points or more
Depends on which NPE you have.
for the NPE 200 it depends on the amt of SRAM, figure 3 high speed ints.
(100bm or >)
for NPE 225s
Its on a "points" basis. with 600 points per bus. use full duplex numbers for any interface..i.e 200mb for faste 32 mb for token ring ( I just know you guys still have some).....
The bellevue S.E.s have a doc...I'll try and root it out
vmiller Fri, 01/10/2003 - 09:47
I emailed you the doc on 7200 b/w capacity
