01-09-2003 05:33 PM - edited 03-17-2019 07:57 PM
What are the options to use my H320 legacy ISDN point-to-point devices
over an IP Network WAN link.
I just want this. What the options that I have ?
Tanks
Solved! Go to Solution.
02-03-2003 06:43 AM
If you didn't get an answer you can try Cisco's terminal adpater.
F. Brown
01-15-2003 02:00 PM
Did you by chance figure this one out yet?
02-03-2003 06:43 AM
F. Brown
02-14-2003 08:10 AM
Note that Cisco has end-of life'd the IPVC 3530 VTA.
02-14-2003 08:13 AM
Most newer VC systems support both H.323 and H.320 interfaces. If you have an older system that support only H.320, it is recommended to get a new codec that supports both protocols if possible. The cost/complexity of adapters/gateways ( ~$4k) for this function is about as much as a new codec in many cases
