Warning message
Basic config question
Jan 10th, 2003
Customer wants 3550 Series switch cause needs 10 fiber and 2gb
The 3550 goes to (2) 2912 series w/ 12 100fx 2gbic
The 3550's fo to 2950 2410/100 2 fiber.
I need help on which 2950 model is best and the config of the 2912 and 3550
From what I have been able to gather from your question, I understand that you are looking for information on the configuration guide for 2912 and 3550. Here are the links for them
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2900/cgcr29k/index.htm
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/index.htm
Also the Product literature and documentation of the 2950 series are available at:
http://www.cisco.com/warp/public/cc/pd/si/casi/ca2950/
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/
Apart from the Regular Cat 2950 switches, there is the new Catalyst 2950 LRE switch which also features Gigabit Ethernet connectivity via either fixed 10/100/1000 ports or SFP ports.
