Warning message
No Trap from Cat1900 to CW2K
Jan 11th, 2003
Hi All,
I'm having a campus network with Cat1900 switches (Ver V9.00.04 Enterprise Edition) and Cisco Works 2000 NMS. All the devices are visiable in the RME database - showing in Availability Monitor, can view the device using Cisco View, showing in the Topology diagram. Trap is enabled in the Cat1900. But no messages are getting logged into the Syslog. All other switches and routers in the network are sending error messages into the Syslog.
Pls suggest possible solution.
Malay.
rmushtaq Sat, 01/11/2003 - 22:44
  • Blue, 1500 points or more
What is the RME version and specific 1900 model?
mgoswami Sun, 01/12/2003 - 01:07
Thanks for response.
The RME ver is 3.3.
We are using WS-C1912C-EN & WS-C1924-EN model of Cat1900.
Firmware Ver is V9.00.04. I tried with Firmware ver V9.00.06 also in one Cat1900, but no go.
Can U pls confirm whether it is possible to have Syslog messages from Cat1900? If yes how.
All the SNMP traps are enabled in the Cat1900 as shown below.
WIB405#sh snmp traps
Authentication trap: Enabled
Link up/link down trap: Enabled
Address violation trap: Enabled
Broadcast storm control trap: Enabled
VTP traps: Enabled
Host Community String
10.1.1.10 public
WIB405#
Now the problem is I'm not receiving any messages from Cat1900 in my NMS (10.1.1.10). Its not clear if I need to do anything in the NMS (CW2K) to enable receiving Traps from Cat1900. Pls tell how can I log events (say link Up/Down) form Cat1900 into my NMS and how to view the log or generate report.
Malay.
rmushtaq Sun, 01/12/2003 - 20:18
You're mixing up traps with Syslog messages. According to RME 3.3 Supported Device List at: http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_3_x/3_3/e3_3.htm#69121
RME 3.3 does not support Syslog Analysis for Cat1900 as under the Syslog Analyzer you'll see Not Supported listed above for the Cat1900. As for the traps, RME is not a Trap listener application either.
mgoswami Mon, 01/13/2003 - 00:23
Thanks for clarifying tarps and Syslog messages. Now can U suggest a work around for logging trap messages (Link Up/down, Authentication etc) from Cat 1900. We are having DFM1.1. I'm not conversent with DFM. So if U suggest something to do with DFM, pls tell in details, considering I dont know much about it.
Many thanks in advance.
rmushtaq Mon, 01/13/2003 - 10:36
I'd suggest that you look into the DFM User Guide for details on how to use it with your switches.
