Warning message
HELP PLEASE!!!!SWITCH CLUSTERING PROBLEM OR SOMETHING????
Jan 15th, 2003
ok here is the deal....I am trying to add a 2950 cisco switch to a cluster of 2 other switches thru a gbic interface...I have the IP assigned to the vlan1...it seems everything is hooked up correctly and I check config files against the other two switches and everything seems the same...does anyone know what the problem might be????I cannot for the life of me figure out what else to do to be able to see the switch on the network....any help is greatly appreciated...thanks
lgijssel Wed, 01/15/2003 - 23:23
  • Red, 2250 points or more
This is a pretty vague description. I understand that you are not able to ping or telnet to the switch? Does a PC that is attached to it work properly?
Please show us some config if we are supposed to be of help.
