Warning message
VMS 2.1 : Installation Sequence ??
Jan 20th, 2003
Hi, i would like to install the following components of the VMS 2.1 Bundle on the same server:
Cd one 5th, RME 3.4, Common services 1.0, IDS MC, PIX MC ,Security Monitor.
I know that first i must install cd one 5th. My question is: After Cd One i must install RME or Common Services? Wath happen if i install rme for last?
Many thanks in advance
Luca Malaguti
lmalaguti Mon, 01/20/2003 - 11:41
I alredy know this but I would like to know if I must install RME before or after Common Services, and why.
rmushtaq Mon, 01/20/2003 - 11:45
  • Blue, 1500 points or more
CD-One then Common Services and then other apps. For RME if you need to use it then you have to install it.
