Cisco 1601
Jan 20th, 2003
I have 1601, i cannot access the router through console port , session dos not
start.
any solution for this
manish young
Overall Rating: 1 (1 ratings)
thisisshanky Mon, 01/20/2003 - 23:46
Did u check the cable, and the connectors used to access the console ??
Also please check the Hyperterminal (or the software u r using) settings...?? It should 9600 8 1 No flow control..
Hope that helps..
manish-young Tue, 01/21/2003 - 00:51
hi agian,
i have tried diffrent connectors & correct hyper terminal setting, but it dosent work.
manish young
a.manosca Tue, 01/21/2003 - 01:03
Assuming the router is not active/running,
if you have used/done the following:
1. Correct COM port and Hyperterm settings:
- 9600 baud
- 8 databits
- no parity
- 1 stop bit
- no flow control
2. Correct and working console cable
(A console cable that was previously used in other routers or switch)
and if nothing is displayed in your teminal window after powering ON the
router, then it could be a defective console port or probably a defective router.
manish-young Tue, 01/21/2003 - 03:47
thanks,
i think my router's console port is gone ,bec i can access through telnet
with regards
manish young
