OSPF Route - Not In the routing table - reg
Jan 21st, 2003
The SHOW IP OSPF DATABASE output reflects the specified network, whereas the same is not getting installed in the routing table. Please throw some light on this.
deilert Tue, 01/21/2003 - 09:58
  • Silver, 250 points or more
can you show the output of sh ip o dat & sh ip route . Also what kind of router is it ?
k.sadagopan Tue, 01/21/2003 - 10:37
Router#sh ip ospf data | incl 203.195.211.12
203.195.211.12 203.195.198.137 838 0x80000004 0xF601 0
Router#sh ip route 203.195.211.12
Routing entry for 203.195.211.0/24
Known via "static", distance 254, metric 0 (connected)
Routing Descriptor Blocks:
* directly connected, via Null0
Route metric is 0, traffic share count is 1
deilert Tue, 01/21/2003 - 11:04
sh a sh ip o dat external 203.195.211.12
the route is in your routing table it is forwarding it to null 0
is there a static route to null 0
what does a sh ip route staic show ?
