Warning message
cannot receive call during SRST mode.
Jan 21st, 2003
I have a 3620 router, configured as SRST gateway. During SRST mode, I was unable to receive any call from PSTN, I have to dial the full digits to make PSTN call. i don't have the debug info now. Append is the configuration, what could have gone wrong:
clock timezone singapore 8
voice-card 1
ip subnet-zero
no ip domain-lookup
ip audit notify log
ip audit po max-events 100
class-map match-all voip-media
match access-group 100
class-map match-all voip-sig
match access-group 101
class-map match-all voipmedia
match ip dscp 46
class-map match-all voipsig
match ip dscp 26
policy-map wanqos
class voipmedia
priority 1000
class voipsig
bandwidth 200
class class-default
fair-queue
policy-map mark2zero
class class-default
set ip dscp 0
policy-map voip-qos
class voip-media
priority 1000
class voip-sig
bandwidth 200
class class-default
fair-queue
policy-map dscp2cos
class voipmedia
set cos 5
class voipsig
set cos 3
isdn switch-type basic-net3
voice rtp send-recv
voice class codec 100
codec preference 1 g711ulaw
voice class h323 10
h225 timeout tcp establish 3
fax interface-type fax-mail
mta receive maximum-recipients 0
controller E1 1/0
pri-group timeslots 1-31
translation-rule 389
Rule 1 638937.% 37 ANY abbreviated
translation-rule 9
Rule 0 ^.% 9
translation-rule 68266
Rule 0 ^682661.% 1
Rule 1 ^682662.% 2
Rule 2 ^682663.% 3
Rule 3 ^682665.% 5
interface BRI0/0
description Backup ISDN 64K for BMRC Leased
no ip address
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer pool-member 1
no fair-queue
ppp authentication chap
interface Ethernet0/0
bandwidth 100
ip address 10.178.203.254 255.255.255.0
no ip route-cache
no ip mroute-cache
full-duplex
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.178.203.254
interface Serial0/0
description 2048K Leased Line to Science Park
bandwidth 2048
backup delay 0 20
backup interface Dialer0
ip address 10.178.221.4 255.255.255.248
encapsulation ppp
no ip mroute-cache
service-policy output wanqos
interface Ethernet0/1
bandwidth 100
no ip address
no ip route-cache
no ip mroute-cache
shutdown
full-duplex
interface Serial1/0:15
no ip address
no ip route-cache
no logging event link-status
isdn switch-type primary-net5
isdn incoming-voice voice
isdn T309-enable
isdn send-alerting
isdn sending-complete
no cdp enable
interface Dialer0
ip address 10.178.221.3 255.255.255.248
ip access-group 102 in
encapsulation ppp
dialer pool 1
dialer idle-timeout 900
dialer string 68730244
dialer-group 1
ip classless
ip route 0.0.0.0 0.0.0.0 10.178.221.1
ip route 10.178.192.0 255.255.255.0 10.178.221.1
ip route 10.178.196.0 255.255.255.0 10.178.221.1
ip route 10.178.204.0 255.255.255.0 10.178.221.1
no ip http server
no ip pim bidir-enable
logging history debugging
logging trap debugging
logging 10.178.203.1
access-list 100 permit udp any any range 16384 32767
access-list 100 permit udp any range 16384 32767 any
access-list 101 permit tcp any host 10.178.196.1
access-list 101 permit tcp host 10.178.196.1 any
access-list 101 permit tcp any host 10.178.196.2
access-list 101 permit tcp host 10.178.196.2 any
access-list 102 deny tcp any host 10.178.196.1
access-list 102 deny tcp host 10.178.196.1 any
access-list 102 deny tcp any host 10.178.196.2
access-list 102 deny tcp host 10.178.196.2 any
access-list 102 permit ip any any
dialer-list 1 protocol ip list 102
call rsvp-sync
voice-port 1/0:15
mgcp profile default
dial-peer cor custom
dial-peer voice 200 voip
incoming called-number .
destination-pattern 68266[1-3,5]..
progress_ind setup enable 3
translate-outgoing calling 9
translate-outgoing called 68266
voice-class codec 100
voice-class h323 10
session target ipv4:10.178.196.2
dtmf-relay h245-alphanumeric
ip qos dscp cs5 media
ip qos dscp cs3 signaling
no vad
dial-peer voice 100 pots
destination-pattern 9[6,9].......
progress_ind alert enable 8
direct-inward-dial
port 1/0:15
dial-peer voice 101 pots
destination-pattern 9018T
direct-inward-dial
port 1/0:15
prefix 018
dial-peer voice 102 pots
destination-pattern 9800T
direct-inward-dial
port 1/0:15
prefix 800
dial-peer voice 103 pots
destination-pattern 91800T
direct-inward-dial
port 1/0:15
prefix 1800
dial-peer voice 104 pots
destination-pattern 91900T
direct-inward-dial
port 1/0:15
prefix 1900
dial-peer voice 105 pots
destination-pattern 91...
direct-inward-dial
port 1/0:15
prefix 1
dial-peer voice 106 pots
direct-inward-dial
port 1/0:15
prefix 1
dial-peer voice 107 pots
destination-pattern 99..
direct-inward-dial
port 1/0:15
prefix 9
dial-peer voice 108 pots
destination-pattern 900T
direct-inward-dial
port 1/0:15
prefix 00
dial-peer voice 201 voip
voice-class h323 10
session target ipv4:10.178.196.1
no vad
call-manager-fallback
limit-dn 7940 2
limit-dn 7960 4
timeouts interdigit 5
ip source-address 10.178.203.254 port 2000
max-ephones 24
max-dn 96
dialplan-pattern 1 68266... extension-length 3
keepalive 10
translate called 68266
call-forward busy 68266195
call-forward noan 68266195 timeout 20000
date-format dd-mm-yy
line con 0
password xxxxxx (moderator edit)
line aux 0
password xxxxxxx (moderator edit)
line vty 0 4
exec-timeout 5 0
end
smalkeric Mon, 01/27/2003 - 14:10
  • Silver, 250 points or more
You can check for known bugs in the Cisco Bug Tool Kit. I found one such bug in the Tool kit, similar to this one. Please check it out.The bug ID is CSCdv75720. The following debugs could help you find out the reasons.
debug vpm sig
debug voip ccapi inout
debug vtsp session
I am not very sure of the solution, if the above bug is the one found in this case.Does anybody has the solution to this?
trailman73 Fri, 01/31/2003 - 14:54
  • Bronze, 100 points or more
Have you tried using the num-exp command? I am using this and it works very well.
num-exp DID EXTENSION
for example: num-exp 7035551212 3062
Geoff
