Warning message
Easy NAT configuration question
Jan 22nd, 2003
I am trying to enable NAT on my 3640, but something is wrong with my configuration. I have a basic static NAT translation with an internal host of 192.168.0.10. The inside router interface is 192.168.0.1. The outside interface is 64.171.42.211 and the gateway is 64.171.42.209. A static route exists to 64.171.42.209. However, NAT is not working because my host which is at 192.168.0.10 can ping 192.168.0.1, but that is it.. Any ideas?
Current configuration : 1084 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Cisco
ip subnet-zero
ip name-server 206.13.28.12
ip audit notify log
ip audit po max-events 100
fax interface-type fax-mail
mta receive maximum-recipients 0
interface Ethernet2/0
description Intranet
ip address 192.168.0.1 255.255.255.0
ip nat inside
half-duplex
no mop enabled
interface Ethernet2/1
description Internet
ip address 64.171.42.211 255.255.255.248
ip nat outside
half-duplex
interface Ethernet3/0
no ip address
shutdown
half-duplex
interface Ethernet3/1
no ip address
shutdown
half-duplex
ip nat inside source static 192.168.0.1 64.171.42.211
ip classless
ip route 0.0.0.0 0.0.0.0 64.171.42.209
ip http server
ip pim bidir-enable
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
exec-timeout 0 0
password Cisco
logging synchronous
login
line aux 0
line vty 0 4
password Cisco
login
end
Overall Rating: 4 (1 ratings)
ali-franks Wed, 01/22/2003 - 01:52
Remove:
Add
ip nat inside source list 1 interface Ethernet2/1 overload
access-list 1 permit 192.168.0.0 0.0.0.255
That'll do the trick
Ali
a.manosca Wed, 01/22/2003 - 01:59
  • Bronze, 100 points or more
Hi, your objective is not quite clear but here are some info:
It is normal that the host (192.168.0.10) is able to ping
the Ethernet2/0's ip add because they are on the same segment
and no translation should happen because the packet will not
be 'switched' to Ethernet2/1.
However, if you want to use Ethernet2/1's public ip add (64.171.42.211)
as your host's outside ip add, you can try the following config:
access-list 1 permit host 192.168.0.1
access-list 1 permit host 192.168.0.10
(The above config allows only Eth2/0 and the host to be
translated using Eth2/1's ip add)
(remove the "ip nat inside source static 192.168.0.1 64.171.42.211" )
So I guess what you want to achieve is for the host (192.168.0.10)
to be able to access the outside (or the internet) using the
ip address 64.171.42.211.
Hope this helps.
sp2960655 Wed, 01/22/2003 - 08:10
I want the host at 192.168.0.10 to be able to get on the Internet. So far, the IP NAT TRANSLATIONS shows nothing. The 192.168.0.10 MIcrosoft Windows XP-based host can ping 192.168.0.1 (the host gateway and DNS server is defined as 192.168.0.1). The 192.168.0.10 host is connected to a Cisco 2924XL switch (it also has an inside address but for management purposes), which is then connected to the router.
A static default route goes to 64.171.42.209, which is the ISP gateway.
version 12.2
hostname Cisco
enable secret 5 $1$3rNz$QK9.t4zOpmVzIKXNKxBQ9.
ip subnet-zero
ip audit notify log
ip nat inside
half-duplex
no mop enabled
ip nat outside
half-duplex
no ip address
shutdown
half-duplex
no ip address
shutdown
half-duplex
ip classless
ip http server
ip pim bidir-enable
access-list 1 permit 192.168.0.10
call rsvp-sync
line con 0
exec-timeout 0 0
password Cisco
logging synchronous
login
line aux 0
line vty 0 4
password Cisco
login
end
