VPN Concentrator 3030 and PIX 501 - Windows Domain login Problem
Jan 22nd, 2003
I have a PIx 501(in a Cablem modem) creating a vpn tunnel (IPSEC), in Client Mode, to a Cisco 3030 Concentrator. I am not able to log into our windows domain (problem registering the workstation behind the PIX). I am able to ping the Domain Controler, and everything else seems to work fine.
Any idea in how to solve this?
If my laptop is behind the PIX I can log into the domain with the accounts that were previously logged in in the LAN, no other account can do it. I can map drives, and run loggin scripts. But the problem seems to be the ability to register the workstation in the domain, and allow a new user to log into the domain using the workstation(laptop).
I am not able to ping the ip assigned to the PIX 501.
Do I need NEM too allow this kind of communication to happen? As soon as I switch to NEM mode, I don't have communication with the corporate network, the session appears alive in the 3030 (Monitoring|Sessions) , but no IP was assigned to the PIX. What do I need in my Concentrator to make NEM work? (other that allow NEM authentication).
any suggestion would be highly appreciated.
Luis
mike-greene Wed, 01/22/2003 - 14:40
  • Bronze, 100 points or more
Hi, Can you post your 501 config....this might help.
