Warning message
Configuring SNMP variables on CatIOS
Answered Question
Jan 22nd, 2003
Anyone know what are the commands needed to configure the chassis ID on a CatIOS switch? That is I'm looking for something equivalent to the command "snmp chassis-id" on an IOS switch/router. Thanks in advance.
Correct Answer by milan.kulik about 14 years 7 months ago
AFAIK there is a SNMP engine ID used on CatOS but you are not able to change it.
I'm using set system location or set system contact to define my device inventory numbers.
Milan
Overall Rating: 5 (1 ratings)
Correct Answer
milan.kulik Wed, 01/22/2003 - 23:44
  • Red, 2250 points or more
Milan
