How to track the big broadcaster in the LAN
Answered Question
Jan 23rd, 2003
We have cisco switches in and cisco routers connected to the LAN. Don't know how to prevent someone from sending out big amount of broadcasting from his/her client pc. Supposed the destination and source of the packets are 255.255.255.255 and 0.0.0.0. It's hard for us to find who send out these huge amount of packets. Appreciate some one could provide some comments.
Correct Answer by jmcoffey about 14 years 6 months ago
Since these ARE broadcasts and routers do not pass broadcasts (normally) the the broadcasts are definitely coming from the subnet you are seeing them on. Now that the obvious is covered... :-) the only way you will be able to track these down IMHO would be to disconnect devices, possibly in a binary search, and monitor with sniffer. I realize this may be inpractical, esp. during working hours, but if these are present at all times then it may not take all the long during an after hours with two people. One disconnecting switches/hub etc. while the other person is sniffing the network. Once the network device (switch/hub) is identified then you'll need to disconnect one connection at a time.
I do not see any other way to do it
Jim Coffey
Correct Answer by a.manosca about 14 years 6 months ago
Sorry about that, here are the links again (without login):
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008007f2b9.html
http://www.cisco.com/en/US/products/hw/switches/ps607/products_command_reference_chapter09186a008007e90c.html#xtocid1214010
http://www.cisco.com/en/US/products/hw/switches/ps646/products_configuration_guide_chapter09186a008007e707.html
However, you mentioned you cannot find the source of the broadcast using the
sniffer. But were you able to verify that the packets you have captured includes the broadcast packets you mentioned? Maybe you can try looking for a source MAC address.
Goodluck.
Overall Rating: 5 (2 ratings)
jeffrey.zhou Fri, 01/24/2003 - 00:20
I think Sniffer is the best tool you can use to track the broadcaster.
a.manosca Fri, 01/24/2003 - 00:41
  • Bronze, 100 points or more
johnleee Sun, 01/26/2003 - 16:20
Hi Manosca, I have difficult to open these linkages as registered user is required while I could hardly get the id from vendor.
johnleee Sun, 01/26/2003 - 16:04
Hi Jeffrey, from the sniffer, it's still hard to find the source broadcaster as the packet information does not contain that, the source address is only 0.0.0.0.
Correct Answer
a.manosca Sun, 01/26/2003 - 16:56
Goodluck.
johnleee Sun, 01/26/2003 - 17:13
Yes, the source address fields were all zero. thanks.
Correct Answer
jmcoffey Mon, 01/27/2003 - 10:00
Jim Coffey
jmcoffey Mon, 01/27/2003 - 10:05
Are these DHCP packets (UDP port 67/68)? If so then you have a PC that can not connect to a DHCP server and is probaly misconfigured to has a connection (layer 2) problem to the network i.e. xmit but no receive.
Just a thought...
Jim Coffey
wilsons5 Mon, 01/27/2003 - 10:57
John;
If you use a sniffer to capture the broadcast packets, you should be able to get the mac address of the device. Once you have that information you can track the offensive device down via the cam table on your cisco switches. The cam tables will lead you to the specific port which the pc is attached.
Sean
