VPN client 1.1 to IOS router
Jan 24th, 2003
We try to connect branches from our company over the Internet by using VPN client 1.1 due the IOS version running on perimeter router. The VPN connection are between client and the perimeter router.
After the full configuration we observed that all the trafic are passing through non-secure connection and not through the tunnel. The client configuration stipulated to obtain IP addresses from a dedicated pool with values from the network segment located back to the perimeter router. It seems that the client doesn't feel the VPN tunnel. Also the router in debug mode nothing reported.
Does anybody know why this hapenning and some documents to help us or some advices ?
Thanks for your cooperation
cjacinto Wed, 01/29/2003 - 00:13
  • Cisco Employee,
Looks like a misconfiguration on the the client. See the sample config on:
http://www.cisco.com/warp/customer/707/ipsec_c.html
Also review the debugs on the router to see if the client is connecting or establishing the tunnel properly. On the router also try to disable fast switching on the interface the crypto map is applied, ie no ip route-cache.
