Warning message
Regarding upgrading from ACS 2.3 to 3.1
Jan 30th, 2003
Here is what I want to do. Install 3.1 on a new separate 2000 server and copy all the configurations from 2.3 to 3.1. The 3.1 is the trail version.
Also want to know after I do the above successfully will I be able to retain the 3.1 configs when I upgrade from 3.1 trial to 3.1 commercial once I decide to buy the same.
mohammed.ibrahim Thu, 01/30/2003 - 17:37
I did findout about the csutil which can be used to migrate user and group information from one server running 2.3 to another (which can be even 3.1). Is there anyother utility I can use to transfer the whole config information from the 2.3 server to the 3.1 server.
