Remote VPN client supported on PIX 501?
Jan 31st, 2003
Is the Cisco VPN client supported on the PIX 501? If so, what versions are supported? Does anyone have a working sample config they could share for remote (dynamic) vpn clients accessing a Cisco PIX Firewall?
Kind Regards,
Dan
daniel.kline Fri, 01/31/2003 - 18:14
Thank you, Arul. I did stumble upon this URL after I posted this message. The VPN configurations get a little confusing with compatibility and configuration issues between the varying versions of PIX OS and VPN Client (IPSec, L2TP, PPTP) software, not to mention the various VPN Concentrator and Router IOS VPN software. I am working primarily on firewalls with PIX OS version 6.1 and higher. I assume that the Cisco VPN (IPSec) Client 3.6 is the recommended client software.
Dan
[email protected]
