Warning message
CCM 3.2(2c) CPU Usage 100% cause Telephony Call Dispatcher service
Feb 3rd, 2003
Hi everbody
Our CCM 3.2(2c) goes often to CPU Usage 100%, and don't leave it.
We think that is caused by the Cisco Telephony Call Dispatcher service.
We stop and start the service and the CCM goes ok, for about 8/9 hours.
All services are working perfectly, no error messages except for the above service.
We have CM integrated with AD
Are any way to avoid this situation?
Thanks in advance
MP
MARIO PAIVA Mon, 02/03/2003 - 08:50
Thanks for your help.
Which is your service pack of Sql ?
Mp
dpyee Tue, 03/04/2003 - 14:06
Turn off Audio Translator service when not in use. We found this was causing high CPU on CM3.2.2c.
marinaibm Tue, 03/04/2003 - 20:47
  • Silver, 250 points or more
There are many bugs related to TCD. You better disable the service if you dont use it or install the latest Attendant Console version .
