Cisco Secure 3.1replication
Feb 4th, 2003
Problem with CS3.1 where the database replication fails. Both servers have been setup according to the online docs
I get "denied replication request" on the primary and "Inbound database replication from ACS denied" on the secondary
Anyone had any issues with this?
mchin345 Tue, 02/11/2003 - 08:13
  • Silver, 250 points or more
Check the following steps to check your Database configuration
Make sure you have set the server correctly as either Send or Receive.
On the sending server, make sure the receiving server is in the Replication list.
On the receiving server, make sure the sending server is selected in the Accept Replication from list.
Make sure that the replication schedule on the sending Cisco Secure ACS is not conflicting with the replication schedule on the receiving Cisco Secure ACS.
If the receiving server has dual network cards, on the sending server add a AAA server to the AAA Servers table in Network
Configuration for every IP address of the receiving server. If the sending server has dual network cards, on the receiving server add a AAA server to the AAA Servers table in Network Configuration for every IP address of the receiving server.
For more details check the following URL
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_user_guide_chapter09186a008010216a.html#211247
jjnetworks Tue, 02/11/2003 - 09:11
I have had this working in the past with ver 2.6. Just can't get the servers to replicate. I've checked what is suggested, but to no avail. I have now raised the issue with our SE
Thanks for your reply
gfullage Tue, 02/11/2003 - 15:04
  • Cisco Employee,
Actually the previous post was a little incorrect. On the receiving server make sure the primary server is NOT included in the Replication Partners section. This had to be the case in v2.6 and earlier, but it changed in 3.0. Remove the primary from the Partners list and then see how you go.
