NAT ISSUE HELP !!
Feb 5th, 2003
Hi ,
I have got a nat problem I believe ;I am a novice hence this query .
Ok issue is VPN client cant access internal network .Vpn Client connects ok .
Some error messages on pix console when i try and ping inside network are .
No translation group found for udp src outside:100.100.25.100/137 dst inside:100.100.1.98/137
Network Config
Inside Network 100.100.1.XXX
OutSide Network say 40.40.204.xxx
PIX VPN INSIDE 100.100.1.4
PIX VPN OUTSIDE 40.40.204.4
default border router 40.40.204.1
access-list 90 permit ip 100.0.0.0 255.255.255.0 100.100.25.0 255.255.255.0 (hitcnt=0)
nat (inside) 0 access-list 90
Now the Inside network has a gateway to a router 100.100.1.251
whose config is
interface Ethernet0/0
ip address 100.100.1.251 255.255.255.0
ip access-group 102 in
ip nat inside
interface Ethernet0/1
ip address 40.40.204.23 255.255.255.0
ip access-group 101 in
ip nat outside
ip nat pool ovrld 40.40.204.240 40.40.204.240 netmask 255.255.255.0
ip nat inside source list 7 pool ovrld overload
ip classless
ip route 0.0.0.0 0.0.0.0 40.40204.1
ip route 100.100.0.0 255.255.0.0 100.100.1.254
access-list 7 permit 100.100.0.0 0.0.255.255
access-list 101 permit ip any any
access-list 102 permit icmp any any echo
access-list 102 permit ip 100.0.0.0 0.255.255.255 100.0.0.0 0.255.255.255
access-list 102 permit ip any 40.40.204.0 0.0.0.255
access-list 102 deny ip any any
Inside Pool given to road warrior using l2tp ipsec win2k client 100.100.25.10 -100.100.25.20
regards
Raj .
awaheed Wed, 02/05/2003 - 12:41
  • Cisco Employee,
Hi Raj,
This log appears when a NAT and global command cannot be found for a protocol. The protocol can be TCP, UDP, or ICMP, kindly check your Statics/Globals as they maybe causing this.
Hope this helps,
Thanks and Regards,
Aamir Waheed,
Cisco Systems, Inc.
CCIE#8933
