CiscoWorks2000 Evaluation
Answered Question
I have recently received an evaluation version of CicsoWorks2000 LMS ver. 2.1 and RWAN ver 1.2. Combined, there are 7 CDs that I will load. My question is: Other CD One, is there a specific order that I should install the software?
The CDs are as follows:
CD One 5th Edition
Resource Manager Essentials version 3.4
Campus Manager version 3.2
Device Fault Manager version 1.2
nGenius Real-Time Monitor version 1.4
Access Control List Manager version 1.4
Internetwork Performance Monitor version 2.4
Thanks for your assistance.
John
Correct Answer by rmushtaq about 14 years 6 months ago
You need to install CD-One first and others can be installed in any order except for ACL Manager which requires RME to be installed first. RTM is a separate application and does not require CD-One or another apps to be installed first. Better if you install RTM on a separate server. Refer to the Install Guides for more details:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/index.htm
Overall Rating: 5 (1 ratings)
Correct Answer
rmushtaq Wed, 02/05/2003 - 13:27
  • Blue, 1500 points or more
