Catalyst 4006 Port Question
mulhollandm Thu, 02/06/2003 - 07:56
Ping the ip address & then type sh arp
This will show the mac address resolved to the ip address and the port the mac address is associated with.
If you have other switches attached you may need to drill down thru them.
On some other switches you'll need to use a sh mac-address-table from enable mode to trace everything
good luck
darrenj Thu, 02/06/2003 - 07:59
Depending upon your version of IOS, you can use the 'Output Modifiers' tool.
Try this:
Cat_4000#show arp | include x.x.x.x (where x.x.x.x is IP address)
Internet x.x.x.x 11 0002.7da7.affc ARPA Vlan1
This gives you the MAC address of the IP. To find the port where the MAC address is, you then need to enter:
Cat_4000#show mac-address-table | include 0002.7da7.affc
1 0002.7da7.affc dynamic ip,assigned GigabitEthernet2/1
Cat_4000#
You now know that IP address x.x.x.x is out of interface GigabitEthernet2/1! The 'Output Modifier' tool is a way of searching for specific information, for example, 'show arp' would show all entries and it would be a laborious task to search for a specific IP address. The 'Output Modifier' only shows the IP address info you require.
Although this works, there may be a quicker way which someone else might explain!
Dazzler.
