Warning message
Failed Archived Device Summary
Feb 6th, 2003
Has anyone seen this error before?
Telnet: PGM_NM=Configuration Archive:6737:TYPE=unassigned message type::Failed to initiate telnet session, Cannot telnet to U152876_172_31_51_32 RCP: PGM_NM=Configuration Archive:6761:TYPE=unassigned message type::Permission denied.
I receive this when CW2000 tries to archive the configuration from the device.
I can telnet to the device is question. Ive verified the host name. I’m at a lost?
Any help would be greatly appreciated.
Thanks......
rmushtaq Thu, 02/06/2003 - 13:13
  • Blue, 1500 points or more
RME 3.4?. Are the device credentials correct in RME?
jason.phillips Thu, 02/06/2003 - 13:20
RME 3.3. and Resource Manager Essentials 3.3 Incremental Device Update 2.0
When you mention device credentials are you talking about Attributes? If so yes they are all correct.
jegrimm Thu, 02/06/2003 - 14:06
If you go under the RME->Reachability Dashboard and see if your device is up or down..If it is down I would suggest RME->Admin->Inventory->Check Device Attributes and see if the device is responding properly to what you have...
Then troubleshoot from there...Good Luck.
Jim
jason.phillips Thu, 02/06/2003 - 14:18
Thanks.....The device is up becasue I can telnet to it, I also verified it in the RME->Reachability Dashboard. I have also verified the attributes.
Still confused..........
Are you sure you did a telnet from the CW2000 server, not from your workstation? If not, it could be a filter (ACL) issue on the device itself or on an intermediate router.
Do you have DNS operational? Do you use a non-standard TCP-port for Telnet?
Does the problem happen with all devices or just this one?
jason.phillips Fri, 02/07/2003 - 07:21
Yes my original telnet session came from my HPO/CW2000 server. The server uses a host file first then DNS. The device in question gets resolved correcly. I beleive that Im using the standard TCP-port for telnet.
I have a total of 830+ devices and this error is only happening to 9 devices. All other devices archive just fine.......
