Addressing Message after recording it does not work
Recently our users have not been able to address a message after recording the message. It gives them the option to do so, brings them through all the prompts, "adds" the new recipients, but when you go to send the message, you are told the message has no recipients. It doesn't work for messages that have no recipients before recording or if you want to append to the list of recipients (only the original recipients are listed). We're running Unity 2.4.6. Any places I can check to see why this is happening and to fix, or to disable the feature altogether? Thanks.
