How import Cisco MIB's into NetSight Elem Mgr
winfielr
I am using Netsight element manager in a heterogenous network, 50-60 Cisco switches, 100 or so Cabletron blades/Chassis/SSR.
Any helpful comments on importing Cisco MIB's into Netsight would be appreciated. The compiler chokes when I try. Is there a specific sequence?
I am trying at first to just get "Cisco devices & hardware"
All I can get at the moment is the name of the switch and time up with a RO string.
I would like to do RW community strings.
rmushtaq
Level 8
Level 8
MIB loading does have a specfic load order. The MIBs listed under the IMPORTS section are a pre-req and must be loaded first. See: http://www.cisco.com/warp/public/477/SNMP/mibcompilers.html for help
