Warning message
whats wrong about this link?
Feb 9th, 2003
it seems that there has some problem with the DDN link ,i use ping to test another end of the link , there has a strange output:
Reply from 61.*.0.2: bytes=32 time<10ms TTL=224
Request timed out.
Request timed out.
Request timed out.
Request timed out.
,just like that ,so many timed out , i think the link is still connected ,but doesnt work well ,i dont know whats wrong with it ,what should i do?
robhorniachek Mon, 02/10/2003 - 08:49
You might want to try setting the ping timeout to a larger value, just so you can see if the line is very slow.
If you are pinging from a Windows machine, the command is 'ping 61.*.0.2 -w 10000', where 10000 is the number of milliseconds to wait. On a router, do an extended ping and set the timeout higher than the default.
This will show you if the line is really up, just taking 5 seconds to return the ping.
