Pix and vpn client
Feb 11th, 2003
1. Can the pix use a local username and password to authenticate a dial up user using the vpn client?
2. If a user is using the vpn client on his PC which resides on a private address space subnet(RFC1918) and he is natted out by a router/firewall must I disable AH in order for the natting to work - what must I enable or disable for nat to work?
3. Where is a good link on cisco.com to explain the configuration details for doing this?
reinke Tue, 02/11/2003 - 07:51
With R6.22 XAUTH only is possible using RADIUS/TACACS+. LOCAL is not an option.
I am testing 6.3 Beta ... goog news: LOCAL will be an option and it is working fine!
Edgar
