ISDN B channel allocation for Dialers
zgombos
How can I provide always one B channel for both Dialers and two B channels for one Dialer if necessary?
Router1
interface BRI0
encapsulation ppp
dialer pool-member 10 min-link 1
dialer pool-member 20 min-link 1
interface Dialer10
encapsulation ppp
dialer pool 10
dialer max-link 2
interface Dialer20
encapsulation ppp
dialer pool 20
dialer max-link 2
Is this configuration correct?
ssoberlik
Level 4
Level 4
Since you have configured min-link as 1 under the BRI for each dialer, both B-channels have been reserved for outgoing calls, and you will not be able to receive any incoming calls using this BRI interface. And, because you have 'dialer max-link' as 2 under the dialer interfaces, they will use maximum of 2 links together for incoming/outgoing calls.' See if this helps you :
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/dial_r/drdrd.htm#1018987
Last time I checked (about two years ago), dialer max-link only applied to outbound calls and could not be used to control incoming calls. Has this behavior been changed or is the allocation of all channels a special case?
Vincent C Jones
www.networkingunlimited.com
