Warning message
BURST-NORMAL & BURST-MAX
Feb 13th, 2003
Hi All,
I want configure the CAR on a Cisco 7500, to limit web traffic.
I want to understand how can I effectively calculate two parameters of the
"rate-limit" command: burts-normal & burst-max
Thanks in advance,
Bye
G.
teru-lei Thu, 02/13/2003 - 23:02
burst-normal likes Bc in frame-relay, burst-max likes Bc+Be in frame-relay. and the burst-max also is the token bucket size. and the following statement explain how to use:
Router(config-if)#
rate-limit {input | output}
[access-group [rate-limit] number | qos-group number | dscp dscp]
mean-rate Bc Be
The rate-limit meter measures the contract compliance of a traffic class selected with a classifier.
A modified token bucket algorithm is used:
mean-rate specifies average traffic rate.
Bc specifies the normal burst size.
Be specifies the excess burst size.
The token bucket size is defined by Be alone.
Hope that helps.
Best Regards
Teru Lei
c.onate Wed, 04/02/2003 - 11:59
thanks Teru,
but, What it's the time period than we can transmit in a Normal Burst Size?. Thanks.
Cristian
