Warning message
disconnect cause
Feb 14th, 2003
Hi all
i have a table of disconnect causes i get from cisco site
but on my log files i got this message that it doesnt show up on the disconnect cause table:
"DisconnectCause 66 , DisconnectText recovery on timer expiry"
i did several research on cisco site but with no luck can anybody explain what does this means
tks
Erick Bergquist Fri, 02/14/2003 - 22:11
  • Silver, 250 points or more
This Cisco URL has a reference to it in a list. Saids the reaction is to clear also.
http://www.cisco.com/univercd/cc/td/doc/product/wanbu/access/aprod/fpmpmm/fpmmappd.htm
On a few other cause code lists (non cisco) 'recovery on timer expiry' is listed as code 102. One site listed 102 under the "Protocol Error (e.g., unknown message) Class" section.
Google search items I used:
http://www.google.com/search?sourceid=navclient&ie=UTF-8&oe=UTF-8&q=%22recovery+on+timer+expiry%22+%2B66
102 Recovery on timer expiry
A timer expiry initiated an error-handling (recovery) procedure. This problem is typically temporary
ckossmey Mon, 05/19/2003 - 05:30
  • Cisco Employee,
Be aware that sometimescause codes are listed in Hex and other times in decimal. As a previous poster stated 0x66 = 102.
Recovery on timer expiry.
Clay
