Warning message
SPAN in Catalyst 6509
Answered Question
Feb 18th, 2003
We are trying to configure a few SPAN in the same equipment, but only one is allowed. Does anyone know how can I do it?
TIA
here is what you need to do
set span [source{port/vlan}] [destination port ] {here is where you put your options} create
if you do not add the create at the end the current span session will just be erased. if you add the create at the end a new session will be establised.
here is a list of the options.
[rx | tx | both] [inpkts {enable | disable}] [learning {enable | disable}] [multicast {enable | disable}]
"sho span" to verify config.
Mark Goodson
Overall Rating: 5 (1 ratings)
7rbowenii Tue, 02/18/2003 - 13:03
TIA- Look into RSPAN capabilities of the 6509, it should have what you are looking for...
Correct Answer
Mark Goodson
