Warning message
CiscoWorks2000 Syslog analyzer to forward message to another nms server.
Feb 18th, 2003
I have installed the CW2K.
Using the Syslog analyzer, how do I forward logging messages received from network devices to other NMS server?
Thanks.
rmushtaq Wed, 02/19/2003 - 10:44
  • Blue, 1500 points or more
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_3_x/3_4/install/index.htm
The Syslog Analyzer Collector can be installed on a remote UNIX/Windows system to process syslog messages. If necessary, it can also filter the syslog messages before forwarding them to the Syslog Analyzer process on the Essentials server. You can uninstall the Syslog Analyzer Collector later, if you do not want to run it on the remote UNIX server. Hope this helps.
