Question on PIX Static mapping
Feb 20th, 2003
Is it possible to have a one global IP address to be statically mapped to two separate IP adresses (one of them on the inside and one on the DMZ) by specifying the requested port?
I know that you can map multiple global IP addresses to a single internal address by specifing the port, but not sure about the single global to multiple internal.
Thanks in advance!
steve.barlow Thu, 02/20/2003 - 10:40
  • Silver, 250 points or more
You mean something like this:
static (inside,outside) tcp 200.200.200.200 telnet 10.1.1.6 telnet netmask 255.255.255.255 0 0
static (inside,outside) tcp 200.200.200.200 ftp 10.1.1.3 ftp netmask 255.255.255.255 0 0
Hope it helps.
Steve
tvorhauer Sat, 02/22/2003 - 07:12
Yes, that is exactly what I am trying to accomplish.
Thanks for the help!
ovanjara Thu, 02/20/2003 - 10:48
  • Cisco Employee,
Yes, this is possible (port redirection)
I am attaching a link below which talks about this in detail.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_62/cmdref/s.htm#1026694
However as an example below on how to achieve this:
static (inside, outside) tcp 192.168.1.1 ftp 10.1.1.1 ftp
static (inside, outside) tcp 192.168.1.1 http 10.1.1.2 http
Obaid.
