Warning message
thisisshanky Thu, 02/20/2003 - 10:48
  • Purple, 4500 points or more
What is the solution that u need, related to the above ?
joytaylor Thu, 02/20/2003 - 12:33
I have an existing frame-cloud. We ordered a second frame cloud to do some
load balancing and/or redundancy. The second frame cloud is terminated into a different router. We are currently using OSPF for routing. My question is what is the best way to incorporate this second frame cloud. Should I include this cloud into the existing's cloud's area? How do I load balance between the two clouds?
thnx
thisisshanky Fri, 02/21/2003 - 00:31
Is the second cloud terminating on either ends on different routers ??
That is Rtr A - service provider 1 - Rtr B and
also Rtr C - service provider 2 - Rtr D
OR
RtrA - service provider 2 - Rtr C
Just to know the topology.
joytaylor Fri, 02/21/2003 - 10:20
The first option, seperate clouds, separtate routes. Rtr A and Rtr C are connected to same cat5500 switch. Rtr B & Rtr D connected to same cat4006 switch. Rtr A and RtrC are doing HSRP. RtrC is the active.
thisisshanky Fri, 02/21/2003 - 11:34
I think your best bet in this case would be to configure
1. the remote lan segment (where routers B and D are present) to be in area 0.
2. Put the two frame-relay clouds in area 1
3. and the lan segment (where routers A and C are present ) to be in area 2.
You will need to configure two virtual links one via router C to router D and one via router A to router B.
Also while configuring HSRP, both C and A should be enabled with HSRP interface tracking. C would be tracking its serial interface, and normally C would be passing all traffic (since C is active router). When the frame cloud at C fails, or router C fails, router A becomes active, also virtual link via C to D will become down, and OSPF will now converge via the virtual link from A to B. This way you can achieve redundancy and failover.
Hope that helps!
