Warning message
VMS 2.1 & Monitoring Center for Security as a Central Console
Feb 21st, 2003
I installed the Monitoring Center for Security and I like to receive the alarms of Network IDS, Host IDS, Rotuer with IOS/IDS and PIX Firewalls.
At Event Viewer console I saw several options, for example: ALL IDS Alarms, PIX Security, PIX IDS, IOS IDS Syslog, etc.
But ,what is the option that I must choice if I like to see all the event in the same windows?
Thanks a lot in advance,
Graciela.
pradeepde Thu, 02/27/2003 - 13:24
  • Bronze, 100 points or more
Configuring the 'Monitoring Center for Security' to generate a report for all Security alarms is pretty straightforward. All you need to do is to go to Select Reports > Generate and select the option 'All'. The report can then be filtered for specific events only. More information is availabe at http://www.cisco.com/en/US/products/sw/cscowork/ps3991/products_user_guide_chapter09186a00800e4655.html
