Warning message
passing internet traffic
Feb 22nd, 2003
I have a 1600 series router and a Caymen DSL router connected to the switch. How can I pass the remote site ip traffic from the 1600 to the caymen router out to the internet.
Thanks!
thisisshanky Sat, 02/22/2003 - 10:13
  • Purple, 4500 points or more
Put a default route on the Cisco 1600 pointing to the IP address of the Caymen DSL router (inside interface- lan interface of DSL router)
thisisshanky Sat, 02/22/2003 - 13:25
ip route 0.0.0.0 0.0.0.0
I hope the Cayman router NATs your local ip address for your workstations into the public IP that you get via the ISP.
globalonline Sat, 02/22/2003 - 14:01
this appears to be a incomplete command.
I thank you for you help
thisisshanky Sat, 02/22/2003 - 17:55
I presume you didnt enter the command in the appropriate router mode. You need to enter this command in global config mode.
router>enable
router#config t
router(config)# ip route 0.0.0.0 0.0.0.0
router(config)#ip classless
Hope that helps this time.
