Access ATA186's Web Interface via the Internet
Can I remotely access my ATA186's Web Interface via the Internet?
I have a problem to do so. The ATA186 is behind a firewall, so I need to forward a port number (such as 12345) to the ATA's Port 80. I can access the protection page via the Internet. However, after I input the password, it cannot load the setting page. Anything wrong?
Thank you.
KKH
adignan Sun, 02/23/2003 - 19:17
  • Blue, 1500 points or more
I cannot verify this at this time but what I think is happening is that once you login the ATA page is using Active X controls or Java??? This would require you to open those ports on your firewall? Can you access the ATA internally? This would be a good test to verify that the ATA is working properly.
My .02 cents
